Dimensions Task Settings – Complete Guide
Selection Mode :computer_mouse:
Choose how you place dimensions:
  • By View :framed_picture: – Creates dimensions in your selected views for the specified element categories
  • By Line :pencil: – Draw lines interactively to place dimensions directly in the active view. Released in Glyph 0.8.2.0.
:bulb: Tip: Use By Line for quick, precise placement when you need fine control.
References :straight_ruler:
A reference is the specific point or edge on an element that the dimension line connects to. Different element types offer different reference options:
Family Instance References (Furniture, Equipment, etc.) :couch_and_lamp:
  • Left / Right – Side edges of the family
  • Center Left Right – Centerline between left and right
  • Front / Back – Front and back edges
  • Center Front Back – Centerline between front and back
  • Bottom / Top – Vertical edges
  • Center Elevation – Vertical centerline
Wall References :brick:
  • Wall Center Line – Geometric center of the wall
  • Core Center Line – Center of the structural core
  • Finish Face Exterior/Interior – Surface faces
  • Core Exterior/Interior – Structural core edges
System References :gear:
  • Curve References – For grids, levels (line geometry)
  • Perimeter References – For floors, ceilings (edges)
  • Center Line – For MEP elements (ducts, pipes)
:warning: Important: Some categories allow multiple reference selection (walls, doors, windows, family instance categories (air terminals, lighting fixtures etc)), others are single selection (grids).
Category Selection Structure :card_index_dividers:
Organize what gets dimensioned in two ways:
  • Individual/Single Categories – Configure each category separately
  • Dimension Groups – Combine multiple categories with shared settings. Released in Glyph 2.6.
Dimension Group Settings :knot:
Unlock advanced strategies when you group categories.
Dimension Grouping Strategy
See release notes for more details.
  • :artist_palette: Compose Dimensions“Stack dimensions by layer”
    Control:
    • Order of dimension types
    • Spacing between layers
    • Which options are included from each category
      Great for complex plans (e.g., walls, grids, structural) in clean, layered strings.
  • :link: Combine Categories“Merge categories into one dimension when possible, based on group proximity and selected references”
    Produces unified strings for cleaner drawings with fewer lines.
Group Settings Explained :hammer_and_wrench:
When using Combine Strategy:
  • Automatically applies Group by Proximity & Direction to all categories in the group
When using Composer Strategy:
  • Each category keeps its own grouping settings
  • Full control over layer order and spacing
If Compose is selected:
  • Organize layers (drag & drop, toggle per layer)
  • Set Offset Between Layers (measured in project units)
Individual Category Settings :puzzle_piece:
Reference Selection
  • Single Selection – Most categories (walls, grids, levels)
  • Multiple Selection – Family instances can use multiple reference planes
Element Grouping Strategy :ladder:
Released in Glyph 2.2. & Glyph 3.5
  • Individual Dimensions – Creates a separate dimension for each reference and element selected. No grouping is applied. Example
  • Group by Proximity/Distance – Groups elements that are close together based on the distance tolerance setting. Elements within the specified distance will be dimensioned together. Exampe:
  • Group by Reference Direction – Groups elements that are aligned in the same direction as the selected reference. Uses the direction tolerance to determine alignment. Example:
  • Group by Proximity & Direction– First groups elements by proximity, then further groups them by reference direction. Combines both distance and alignment criteria for optimal grouping. Example:
  • Individual Dimensions With Grouped References - Creates individual dimensions for each element, but groups the references together within the same element. Groups them by reference direction. Example:
Tie Conditions – Connect Your Dimensions :link:
Control how strings connect to other elements:
  • None – Standalone dimensions
  • All: Tie to the Nearest Grid – Extends to closest grid line
  • All: Tie to All Grids Intersecting – Includes all intersecting grids
  • Plan: Tie to the Nearest Joined Wall – Connects to adjacent walls
  • Plan: Tie to the Nearest Grid and Joined Wall – Combines both
  • Elevation: Tie to All Levels Intersecting – Includes intersecting levels
  • Elevation: Tie to All Intersecting Grids and Levels – Maximum connectivity
  • Elevation: Tie to Hosted Level – Connects only to the hosting level. Released in Glyph 2.6
:warning: Important: Tie conditions are view-type specific (Plan vs. Elevation vs. Section).
Wall-Specific Settings :brick:
Wall Location Reference
Plan Views:
  • Wall Center Line
  • Core Center Line
Elevation/Section Views:
  • Wall Height and Openings
  • Mullion Width/Centerline
Wall Dimension Options
  • Interior Walls – Internal layout dimensions
  • Exterior Rough Openings – Opening sizes & positions
  • Exterior Length & Center Openings – Overall length with centered openings
  • Overall Exterior Wall Length – Building perimeter
  • Overall Building – Complete outline
  • Curtain Wall – Panel & mullion dimensions
  • Wall Height and Openings – Section-view dimensions
Category-Specific Options :card_file_box:
Grids :triangular_ruler:
  • Overall – Spanning between grid lines
  • Individual – Bay-by-bay dimensions
Structural Elements :building_construction:
  • All Elements – Dimension everything
  • Aligned Elements Only – Only aligned members
MEP Elements :wrench:
Released in Glyph 2.3
  • To Datum Grid – From equipment to nearest grid
  • Length – Linear element dimensions
Doors & Windows :door:
  • Openings – Size and position within walls
Distance & Style Settings :artist_palette:
Distance Controls :straight_ruler:
  • Dimension Offset – Distance from elements to the dimension line
  • Grouped Proximity Distance – Threshold for grouping nearby elements
  • Grouped Direction Tolerance – Alignment tolerance for directional grouping
    (All values use your project units automatically.)
Style & Behavior :gear:
  • Dimension Style/Type – Choose the appearance
  • Auto Collision – Prevent overlapping dimensions
  • Group Dimensions – Maintain dimensional relationships
  • Custom Datum Grids – Select specific grids for tie conditions
Best Practices & Workflow Tips :light_bulb:
Professional Results :trophy:
  • Start with Composer for complex plans
  • Use Proximity & Direction grouping for family instances
  • Set Tie Conditions to match your standards
  • Tune offsets to avoid overcrowding
Efficiency Boosters :rocket:
  • Enable Auto Collision to prevent overlapping
Troubleshooting :hammer_and_wrench:
Q: Dimensions aren’t grouping as expected?
A: Check proximity and direction tolerances.
Q: Too many grid lines included?
A: Use Custom Datum Grids to limit grids in tie conditions. (MEP categories only)
Q: Dimension layers too close together?
A: Increase Offset Between Layers in Composer strategy.
Q: Family instance references not working?
A: Verify the family has the reference planes you’re targeting in the Family Editor.
Q: Doors/windows not dimensioning correctly?
  • Center of Door/Window – Creates single centerline dimension
  • Rough Openings – Creates left and right edge dimensions
Q: Wall dimensions missing?
A: Check Wall Dimension Options and Wall Location Reference compatibility.
Q: MEP elements not showing?
A: For ducts/pipes using To Datum Grid, set Tie Conditions to nearest grid.
Q: Grouped categories not combining properly?
A: Combine strategy auto-sets proximity/direction — try Composer for more control.
Q: Elevation dimensions not working?
A: Ensure Tie Conditions are set to Elevation options, not Plan.
Posts Featuring Dimension Updates in Glyph Releases :loudspeaker:
Glyph – Release 2.0
  • Group Dimensions settings specifically for walls.
  • Release notes
Glyph – Release 2.1
  • Enhanced dimensioning with linked file support—dimension views/sheets across linked Revit files.
  • Release notes
Glyph – Release 2.2
  • Introduced MEP dimension categories, improved grid dimension support, Composer updates.
  • Release notes
Glyph – Release 2.3
  • Expanded dimension category support (Air Terminals, Ducts, Electrical, Plumbing, Lighting).
  • Release notes
Glyph – Release 2.4
  • Added Room dimension category, improved collision avoidance and UI.
  • Release notes
Glyph – Release 2.6
  • Added Dimension Groups with Combine and Compose strategies for advanced grouping, order, and spacing.
  • Introduced grid options (Overall + Individual) and wall dimension order with drag-and-drop customization.
  • Release notes
Glyph – Release 2.8
Glyph – Release 3.1
Glyph – Release 3.3
Glyph – Release 3.4
