Glyph Release - 0.8.2.0
Features :tada:
  • Dimensions By Line
    • Instead of Glyph dimensioning all your floor plan at once, you can now quickly create a line and Glyph will automatically dimension all the walls that crosses the newly created line.
    • How does it work?
      1. Go to the Dimensions views by category task
      2. Select “By Line” selection Mode
      3. Run the task by clicking on the play button
      4. Select a starting point for your line in your active view
      5. Move your mouse across your plan, this line will be used to create the dimension
      6. Select an end point to your line
        • Revit_LVTvh2yavA
      7. Elements in red represent the elements that will get dimensioned
  • Things to consider:
    • Currently only available for the following categories and view types:
      • Walls / Curtain Walls - Plan views (floor plans, rcps, structural plans etc)
      • Grids - Plan views (floor plans, rcps, structural plans etc)
    • Pick the specific reference layer of the wall in the settings tab (Stud, exterior
      face, interior face etc)
  • Tips:
  • Examples:
    • Wall Dimensions:
      • Revit_h3A9Y8DY6f
    • Grid Dimensions:
      • Revit_USBV9SDeC0
Bugs :bug:
  • Fixed room schedules not changing the filter parameter value of the selected template schedule
Glyph - Release 0.8.2.1
Bug Fixes :bug:
  • Fixed dimensions stuck on “by line” selection mode in certain scenarios.
Glyph - Release 0.8.2.2
Features :tada:
  • Multiple Dimension Wall References for the same dimension
Glyph - Release 0.8.2.3
Improvements :roller_coaster:
  • Metric - Imperial units
    • UI - Units are now displayed in every setting that uses numeric values
      • Imperial: Imperial
      • Metric: image
    • Task Improvements - All offset settings are now taking into account the document units. Before it will always use imperial.
Bugs :bug:
  • Fixed tags selected not saving to project when multiple categories are selected
  • Fixed tag task error when task is in a bundle and throwing the following error “No tag settings found for the category selected”
  • Fixed sheet packing task setting “Views - All View Types” taking legends and schedules from other zones
    • Reference: Sheet pack setting
  • Fixed sheet packing task not placing the right views in the right zones with specific titleblocks
