Glyph - Release 3.3
Download: Installer
Features :tada:
Assemblies support
Assembly views
You can now generate the following Assembly views
  • Floor plan
  • 3D View
  • Elevation Top
  • Elevation Bottom
  • Elevation Left
  • Elevation Right
  • Elevation Front
  • Elevation Back
  • Section A
  • Section B
  • Part List Schedule
  • Material Take Off Schedule
  • Category Schedule (from the assembly)
Bundle
Assembly sheets
Automatically create sheets for Assemblies and place generated views.
New settings/UI
  • Avoid duplicate views and sheets
  • Assembly Category Schedules
    • Create multiple schedules of the same category.
    • Assign different view templates to each schedule.
      wutE6iMfCw
  • Place Views on Sheets – New View Item Filters
Custom Reference Plane Selection
You can now type and use custom reference planes, in addition to the standard Revit reference planes.
Improvements :roller_coaster:
UI
  • Improved task addition to Bundles
  • Improved Bundle creation workflow
  • Bundles are now automatically associated with the active tab
Glyph AI Assistant
  • 15% faster
Bugs :bug:
  • Fixed issue where the β€œAll” tabs appeared twice
  • Fixed issue with Import Sheets by Spreadsheet – Parameter Setter sheet collection
Guides :memo:
