Download: Installer
Linked File Support
You can create views, sheets, dimensions and tag linked Revit elements
How?:
Select the Revit model you want to use for running Glyph tasks by clicking the Linked Model button. -
Supported Tasks & Categories
- Create views:
- Create views by room
- Create Sheets:
- By level
- By scope box
- By room
- Dimensions:
- Dimension views/sheets by category
- Unsupported Categories:
- Doors, windows, levels, railings, and exterior wall dimensions
- Tags:
- Tag views/sheets by category
- Create views:
- Added a parent view search bar
Bugs
- Fixed an issue where the Clear button wasn’t working correctly in the sheet packing layout editor.
- Fixed the Update Available message not displaying properly.
- Fixed a bug where the Run button didn’t update instantly after importing sheets using the Import Sheets by Spreadsheet feature.
Guides
- Looking for help? Check out the Guides.
In Progress
- Adding support for MEP and structural dimension categories.
- Developing the dimension Composer feature, which will add an extra layer of customizability to your dimensioning tasks.
