Download: Installer
Major Dimension Task Release!![]()
Dimension Groups
Organize and control how dimensions are grouped and displayed.
Dimension Categories Selection:
- Dimension Group β Groups categories together
- Add category to Group
- Add dimension group
Dimension Group Settings:
1) Dimension Grouping Strategy
- Combine: Merge multiple dimension categories into a single line
- Compose: Customize the order of dimension elements (e.g., wall, grid)
2) If Compose is selected: Organize layers
3) If Compose is selected: Offset Between layers
4) Individual dimension categories settings inside group
Examples:
Combine Categories
- Plumbing Fixtures and specialty equipment
Compose Categories
Wall, Grids
New features in a Glyph Bundle
- Creates views, dimensions, tags, and sheets, and places those views on sheets.
Task in the ribbon
Download the bundle used in the video above here.
Grid options
- Overall + Individual
Wall Dimension order
- Control the order in which wall elements are dimensioned
- Drag and drop to change the other
Elevation View Support
Dimensioning now works for the following categories in elevation views:
- Plumbing Fixtures
- Specialty equipment
- Electrical Fixtures
- Electrical Equipment
- Furniture
- Generic Model
- Lighting Fixtures
- Mechanical Equipment
Group options
You can now apply the Group Option setting to these categories:
- Specialty Equipment
- Furniture
- GenericModel
New Tie Condition for Elevations
- Tie to Hosted Level
- Example:
Group Dimension Setting
- Group dimension setting added for doors and windows
- Better selection count UI
- Improved dimension grouping behavior
- Rough opening dimensions now include both ends of a wall
- Improved window/door tagging so tag gets placed in the middle in an elevation view
- Improved curtain wall elevation rotation when βView orientationβ is turned on
- Improved offset direction for windows and door dimensions
Bugs
- Fixed an issue where group dimension settings were not saved when the UI was closed.
- Fixed an issue where the level offset did not work properly.
- Fixed an issue where tagging walls in elevation views did not offset correctly.
- Fixed an issue where a 0β β 0" dimension appeared in an exterior wall when an interior wall was connected to a perimeter exterior wall.
Guides
- Looking for help? Check out the Guides.
- Quick start guide
- Additional Resources
