Glyph - Release - 3.1
Download: Installer
Features :tada:
Step-through Guide
A new guided experience to help users get started quickly and efficiently.
Available guides:
  • Complete Tour
  • Quick Start
  • AI Assistant Guide
  • Task / Bundle System
Wall-to-Datum Grid / Axis Dimension Option
Datum grid wall
With this new wall dimension option, you can now tie walls to specific grids or axes.
Tip:
If you don’t want certain walls to be dimensioned, you can filter them out directly in the UI using the following button:
Bugs :bug:
  • Fixed prohibited characters in sheet and view names.
  • Fixed tag offset issues for the following categories:
    • Pipe
    • MEP Fabrication Pipework
    • MEP Fabrication Hangers
    • Conduit (LocationCurve)
    • Pipes
    • Rebar
  • Fixed a Revit 2026 error when creating new Element IDs
  • Fixed annotation collision avoidance settings affecting:
    • MEP Pipework
    • MEP Hangers
    • Ducts
    • Pipe
  • Fixed cases where dimensions displayed as 0'0" for MEP pipework (horizontal and vertical) when dimensioning to datum grids.
Guides :memo:
