With this option enabled, Glyph will reuse existing dimensions (modifying or adding to them where applicable). When disabled, Glyph will create new dimensions, which may result in duplicates.
Benefit: This ensures Glyph reuses dimensions instead of creating the same ones twice, keeping drawings cleaner and easier to manage.
Grid Dimensions
Reusing Furniture Dimensions
Reusing Wall Dimensions
Added casework dimension support in plan view
The “Select All” button now selects only the elements currently displayed, instead of all elements in the list.
Bugs
Fixed issue where room dimensions did not include room separator lines.
Fixed “By Line Dimension Walls – Tie All Grids” condition
Fixed grid dimensions in linked models.
Fixed floor dimensions in linked models (previously not detected when below 0’-0”).
Fixed railing dimensions when a top rail is active.
Fixed structural framing dimensions.
Fixed curtain wall grid dimensions when the Curtain Grid setting (instead of mullion) was selected.
Fixed issue where Glyph would not close after closing all views in a document with linked models, if no other documents were open.
Fixed issue where Glyph tabs were imported into other projects when switching projects, if the document contained linked models.
