Glyph - Release - 2.2
Download: Installer
Features :tada:
  • EULA: The EULA must now be accepted before using Glyph. A notification will appear in the UI whenever the EULA is updated, and it will need to be accepted again.
Improvements :roller_coaster:
  • When creating a view with Glyph that already exists in Revit, it used to add “Copy” labels. Now, it updates the “Title on Sheet” parameter without the “Copy” label before adding the view to the sheet.
Bugs :bug:
  • Fixed center opening dimensions for dimension walls.
  • Fixed parameters that are not saving correctly when closing and reopening the UI.
  • Fixed elements not being tagged when a tag exists for another component inside the wall (e.g., window tags).
  • Fixed Discipline/read-only parameter not showing up in the parameter setter.
Guides :memo:
  • Looking for help? Check out the Guides.
In Progress :clock1:
  • Adding support for MEP dimension categories.
  • Developing the dimension Composer feature, which will add an extra layer of customizability to your dimensioning tasks.
GLYPH 2.2.0.2
To install the latest version, please click the link above.
Bug Fixes :bug:
  • Fixed an error that appeared when using a parameter value that was empty or null in your naming scheme.
  • Fixed a UI bug where the progress bar would get stuck if something failed.
  • Fixed the EULA reappearing when opening the Copilot UI.
GLYPH 2.2.0.3
Bug Fixes :bug:
  • Fixed an error that occurred when tagging linked doors.
  • Fixed linked tagging when the view’s crop box setting is turned off.
GLYPH 2.2.0.4
  • Hid the “Tag end condition” setting for room tags, as this setting is unavailable in the Revit API.
  • Room tags in elevation/section views were previously placed at the bottom of the room instead of the center—this has been corrected.
  • Improved ceiling tagging in elevation/section views.
Bug Fixes :bug:
  • Fixed an issue where Glyph Copilot would get stuck when no multiple-choice option was selected before switching tabs.
  • Fixed the release link on the About page.
  • Fixed tagging of linked elements on the 2nd, 3rd, and higher levels.
  • Fixed tagging of linked elements in section/elevation views.
  • Fixed the room offset setting not working properly.
  • Fixed linked casework dimensions in elevation/section views.
  • Fixed a tag bounding box error that occurred when creating tags too close to the crop box border of a view.
GLYPH 2.2.0.5
Bug Fixes :bug:
  • Fixed a typo in the “Make Room Schedule” UI.
  • Fixed wall section dimensions.
  • Fixed the “Max offset from elements” value increasing when working in a metric Revit model.
  • Fixed the naming scheme UI inside “Make Schedule” (By Room).
  • Fixed rebar tagging in Revit 2023+ for plan and elevation/section views.
  • Fixed the offset setting not working properly for non-family instance elements in elevation/section views.
GLYPH 2.2.0.6
Bug Fixes :bug:
  • Fixed an error involving the dimensioning of cylindrical columns in elevation views.
  • Fixes an issue with filters not functioning properly when a task is added to the Revit window/ribbon.
GLYPH 2.2.1.0
  • Improved expansion behavior for all “Create Views” tasks.
  • Enhanced room schedule creation: You can now map using any schedule filters instead of being limited to Room parameter filters. Additionally, any room parameter can be mapped to a filter, and Glyph will automatically apply it after creating a new schedule. The guide has been updated to reflect these changes.
Bug Fixes :bug:
  • Fixed an issue where the “Add” button in the naming scheme would get stuck when no option was selected.
  • Fixed an issue where the status report open/close button would get stuck when no option was selected.
  • Fixed a bug where tag categories were incorrectly linked across different tasks.
GLYPH 2.2.1.1
Bug Fixes :bug:
  • Fixed an issue where the status report open/close popup would not appear directly underneath the button.
  • Fixed a dimension error when the facing direction is null or (0,0,0).
  • Fixed an issue with the room tag leader condition not working properly.
  • Fixed the tag orientation for room tags.
  • Fixed minor bugs related to dimensioning edge cases.
GLYPH 2.2.1.2
  • Improved compatibility with other Revit add-ins by implementing safe and guard methods to prevent conflicts.
  • Enhanced logging for issues related to sheet packing failures.
Bug Fixes :bug:
  • Fixed the following sheet packing issues:
    • Selected schedule not being placed in the correct location.
    • Room schedule created by Glyph not being placed in the correct zone.
    • Fixed error: “The given rectangle’s anchor point cannot be calculated because the rectangle does not yet have its size and/or location set.”
  • Fixed an error that occurred while dimensioning curved structural framing.
  • Fixed elevation marker offset display issue in the plan view type.
  • Fixed issue importing large amount of tasks/bundles.
GLYPH 2.2.1.3
Bug Fixes :bug:
  • Fixed an issue where Glyph displayed 0 tasks/bundles when working on a new project.
  • Fixed the “Output from Previous Task” setting not updating the Bundle run button.
  • Fixed an error with 00TB tasks.
GLYPH 2.2.1.4
Bug Fixes :bug:
  • Fixed a bug with the “Import Sheets by Spreadsheet” Task in Revit 2025.
