Veras - Release 2.0 - 3D Mode!
Access
3d Mode
The new 3d mode allows for a higher geometry retention. It also enables some really cool workflows
2025-02-14 - 04-28-17 - vlc
2025-02-14 - 12-10-56 - Veedub64
NOTE: 3d mode is currently only supported for Revit, SketchUp, Rhino and the Web App. It’s not supported for Vectorworks, ArchiCAD, Autodesk Forma, Allplan, or the sdk
Select By Material
2025-02-14 - 04-40-53 - Veedub64
Resort Presets
2025-02-14 - 04-46-05
Resort Renders
2025-02-14 - 04-43-14
Favorite Renders
2025-02-14 - 04-49-24
Draw Multiple Shapes
Ability to draw multiple shapes with Render Selection
2025-02-14 - 04-59-09 - Veedub64
Recent Mask History
2025-02-14 - 05-04-23 - Veedub64
+ More
  • 3d Mode
    • Zoom to extents
    • Sync camera to parent app
    • Live sync camera
    • SketchUp, Revit, Rhino and Web app are supported
    • Web app supports OBJ uploads & Axis Alignment
    • Updated 2d/3d toggle UI
  • Render Selection Improvements
    • Undo freehand mask lines
    • Ability to draw all the way to the edge of the canvas
    • Select and deselect polygons & delete selected paths
  • Added user email to the trial expired page
Stability
  • Bug Fix: ‘Cannot Parse Settings’ error the first time a user logs in
  • Bug Fix: Render Selection Mask Cropped for Renderings over 2048 pixels
  • Bug Fix: On auto re-login the ‘Login Form’ would briefly appear
Platform
  • Update Veras to be compatible with the latest Autodesk Forma updates
Security
  • Many security updates
Known Issues
  • 3d mode is currently only supported for Revit, SketchUp, Rhino and the Web App. It’s not supported for Vectorworks, ArchiCAD, Autodesk Forma, Allplan, or the sdk
  • 3d mode large model support is accessible from the Loader 2 setting, and currently has some geometry artefacts
  • Loading an empty model in 3d causes an error fixed in 2.0.3.0
  • Loading a previous mask when changing the window size has alignment issues fixed in 2.0.5.0
  • Need to add a Field Of View setting in the 3d viewer fixed in 2.1
  • SketchUp - if front-face material is default and only back-face has a material, the back-face material does not load in the 3d viewer
  • 3d render selection cannot select unpainted materials
  • 3d render selection cannot select the background
Experimental Features
These features are subject to change, but feel free to try them:
  • Sketching Tools
  • Interrogate Image
Hi - using Veras 2 (trial version) in Rhino7, 3d mode does not seem to work:
  • 3d mode as in the videos above does work, I see something moving in sync with my rhino window but geometry does not come through (I can see the geometry in 2d mode)
  • select by material therefore also doesn’t work, as there is no geometry in the 3d window
  • the web version did not accept my obj files from Rhino, at least I couldn’t see them in the preview
My rhino file is very simple, just a set of boxes on top of eachother, could that have anything to do with it? Does Veras need solids or something?
@miccor - welcome to the forum!
Would it be possible to share your model with us for testing?
Veras - Release 2.0.2.0
Updates
  • Preserve Thumbnail Width when Dragging
  • Auto-update app for non major releases
  • Security Update
Stability
  • Bug Fix: Arrow Keys Scroll Thumbnails Correctly in ‘Favorites’ Mode
Veras - Release 2.0.3.0
Updates
  • Invert Render Selection
  • Hide “My Presets” if there are none
  • Disable the “upscale render” when the scale factor is 1 (no upscaling)
Stability
*need to run the installer to receive update
There still seem to be dot net errors despite updating to 2.0.3.0
This is another error that we’ve worked on, but have not released an update. It’s in testing, slated to be released today or tomorrow.
Veras - Release 2.0.4.0
Updates
  • Change Refresh model icon when in 3d mode
  • Add button to cancel out of Select by Materials in 3d mode
  • Add Veras plugin version number to the window in SketchUp *
  • For Revit and Rhino, the window no longer maximizes to cover the Windows task bar *
Stability
  • Fix Revit Sync 2d Image Bug *
  • Fix bug where switching from 3d selection to drawn selection would not exit the 3d viewer
Veras - Release 2.0.5.0
Updates
  • SketchUp 2025 support *
  • Collapsible My Presets and Veras Presets on the EXPLORE tab
  • UI button text consistency
  • Have text field active by default when Save As preset or Renaming a preset
  • Update refresh model tooltip
Stability
  • Bug Fix: reloading a 3d model would place the selection by material in an additive selection mode
  • Bug Fix: incorrect scale & location of saved masks
  • Bug Fix: mask shape history stability
Veras - Release 2.0.6.0
This is an automatic update for versions 2.0.2.0 and above. For versions below 2.0.2.0, please use the link with the installer in the post above.
Updates
  • Render/Enhance button to be reactive in the EDIT tab
  • Unselect mask shapes when clicking away
  • Faster start render times in 3d mode when the view position does not change
Hi,
when I click on the 3d button my model doesn’t show in the Veras window. What am I doing wrong? It says loading but nothing comes up. I work in Rhino 8.
/ean
Veras - Release 2.0.7.0
Updates
The 3d mode loader will now automatically select the best loading method. This should allow Veras to load 2BG+ models. However, there is still a limit to size, and we’re looking at further expanding this limit.
@eanean & @miccor - this update should address the issue you were having. If it does not, please let us know.
Please forgive the stupid question…for the Automatic update do I need to do anything. I have restarted Revit and still shows the older version.
I had this question as well.
But if you go to the webapp you will see it updated to the latest version.
The installer versions are still not the latest.
Current latest available is 2.0.5.0 from the download link above
@arider & @verma - sorry for the confusion. There’s an Extension Version an a Web Version that you can view under the About Veras menu. A client version for 2.0.7.0 was not released, as there were no source code updates for that part of the app.
Here’s the tooltip text for more info:
For a little more clarity, the Revit plugin will not have the new changes in it as the web app with 2.0.7.0 would have!
The Revit plugin is the web app, but wrapped in a plugin window that has direct communication with Revit.
Alright, is it using WebView for the webpage delivery?
Exactly! The entire UI is loaded within a webview.
Hi Ben, amazing update, I have a specific question to veras, are you guys using the Microsoft Webview 2 SDK? If so are you guys using the webview 2 class or the new webview2 compositioncontrol?
