Veras - Release 1.9 - Presets!
Download: Windows | Mac Sketchup | Mac Vectorworks
  • Custom Presets! - you can now save your favorite settings to Veras for later use
  • New EvolveLAB Presets
    • 21 new refined presets
    • all previous presets were updated to better work with the latest render engines
  • Render Engine 6 Sharp - this increases the geometry retention drastically! Try it out!!
  • New Styles: Cinematic & Film Photography
    • turn these features on to change the mood and aesthetic of the generated render
  • Negative prompts - you can tell the generative AI what NOT to include in a scene
  • Updated the UI organization to flow better with the new features
Stability
  • Fixed a bug where the base image from the base app was not used as structure when rendering with lower geometry overrides
  • Fixed Upscale Menu bug where the resolution was not properly represented
Platforms
  • Vectorworks 2025 is now supported!
New Presets
2024-10-02 - 12-07-24 - ImageGlass
2024-10-02 - 12-23-20 - ImageGlass
Save your own presets!
Along with all the new EvolveLAB presets, you can now also save your own!
To do so, once you have the settings you want to save in the Compose Tab, click on the tree-dot menu button, select Save As, and give your preset a name!
brave_IQNuIS4CQm
These settings will be tied to your account, so you can now use them in any Veras platform (just make sure you’ve installed version 1.9 or later!).
In the dropdown menu, you can also:
  • Save (update the selected preset with the current settings)*
  • Save AS (creates a new preset from the current settings)
  • Rename (renamed the selected preset)*
  • Revert Changes (resets the settings back to the selected preset)
  • Update Image (updates the thumbnail for the selected preset)*
  • Delete (deletes the selected preset)*
* Note: You cannot edit the EvolveLAB presets, only the ones that you have created.
* Note: Trial users can only save up to 10 presets *
Your presets will be visible in both the Preset Gallery in the Explore Tab, as well as in the searchable dropdown menu that appears when you click on the current Preset in the top right.
Veras - Presets - Dropdown
brave_8h6KnMR4Sp
Share your presets!
Made a preset you really like? We’d love to hear about it! You can share it with us and the community by posting a screenshot of your preset along with some renderings you made with it in the Veras Gallery forum!
2024-10-01 - 00-21-22
2024-09-30 - 23-53-16
Cinematic Style
2024-10-01 - 00-06-31 - SketchUp
Film Photography Style
2024-09-30 - 23-59-18 - chrome
Veras - Release 1.9.6.0
Platforms
  • SketchUp 2024 is now supported!
  • Must use version 24.0.593 or higher for Veras to work properly. See steps below to install the SketchUp update.
Install the latest SketchUp 2024
Veras - Release 1.9.7.0
Updates
  • Archicad now includes the open renderings folder button in both Windows and Mac
  • Experimental Features - you can now test out features that are not fully integrated and subject to change. This can be enabled in the settings menu.
  • Interrogate Image - first experimental feature, that allows reverse prompting of uploaded images and renderings generated
Stability
  • Vectorworks and Archicad stability
  • SSO Bug Fix for SketchUp, Revit, and Rhino.
2024-10-31 - 12-30-11
Interrogate Image (Reverse Prompting)
2024-10-31 - 12-33-55 - vlc
Veras - Release 1.9.7.1
Stability
  • Fix for SketchUp 2024 mkdir bug, when auto-saving the render
  • ArchiCAD for Mac stability
Veras just keeps getting better ! Interestingly there was a story just today talking about
how AI prompt creation can be a lucrative side hustle: Mark Cuban's Million-Dollar Advice To Teens: 'If I Were 16 Again, I'd Start This Lucrative Side Hustle'
Thank you, and thanks for sharing the post. It’s really neat!
Here’s a AI generated summary of the post:
  • Mark Cuban suggests that teenagers can start a lucrative side hustle by venturing into artificial intelligence (AI) prompt engineering.
  • His three-step strategy:
    1. Master writing prompts for AI language models
    2. Teach peers to use these prompts for school assignments
    3. Offer services to small and medium-sized businesses that don’t understand AI yet
  • Cuban notes that he would teach these businesses as well, regardless of his age (16)
  • AI prompt engineering can be a profitable opportunity, with average salaries ranging from $30,000 to $129,500 per year.
  • Certifications and practice are essential for mastering the basics of large language models, but a college degree is not required.
  • Online certification programs can help individuals learn the basics within a month.
Our goal is to assist with the prompt engineering, where crafting prompts is a breeze by offering good starting points.
