Ben
February 22, 2024, 10:59pm
V6 Render Engine - major improvements to rendering quality:
darker / richer tones
better color balance
more balanced contrast
less plastic like aesthetic at high prompt strength values
works with black and white sketches
better background / entourage that is not modeled
Render Selection Blend
allows changing the edge blur amount for the render selected image blend with the background render
only available for V6
Integrations
Veras can now be easily integrated in any web app, with a few lines of code!!!
Check out this sample integration with a simple Vue sketch app
Here’s the GitHub repo with the source code and integration instructions
V6 Quality
V6 Sketch Image Input
sketch credit: Dan Kalkman
reference workflow: From Sketch to Render with the V6 Render Engine
V6 Render Selection Blend
reference workflow: Using the Render Selection Blend to Merge Parts of Different Renderings on a Train Station Model
Veras Web App Integration
Ben
February 23, 2024, 7:45pm
2
Veras - Release 1.6.0.1
For certain prompts, the renders would appear to be less sharp on Revit and Rhino when using the new v6 Render Engine . This is now fixed!!
Ben
February 28, 2024, 10:58pm
3
Veras - Release 1.6.2.0
UX Improvements
when uploading an image in the web app, set the aspect ratio as close as possible to the original
when a new render is generated, do not set it as the active one
this prevents the text prompt to be overwritten
added UI new renders badge, to show new renders that have not been viewed
clicking the new render count badge, selects the next new render that has not been viewed
left / right keyboard shortcuts no longer changes the render when a text box is active
ability to delete unwanted renders
updated keyboard shortcuts:
[Ctrl] + [Enter] - start new render
[Delete] - delete selected render
[Shift] + [S] - save selected render
[O] - toggle base / rendered image
[P] - start pen tool in Refine Mode
SketchUp Improvements
adjusted SketchUp base image line thickness to be more pronounced
this allows Veras to more accurately render the geometrical features
vache
February 29, 2024, 7:42am
4
Thanks Ben. Whatever you’ve done 1.6 is producing what seems to me to be images nothing short of divine:
Ben
February 29, 2024, 5:37pm
5
Looking great!
I like the interior kitchen shot the most.
Ben
February 29, 2024, 5:38pm
6
Veras - Release 1.6.2.1
Updates
Reverted the SketchUp base image lineweight to the 1.6.0.0 values.
Muy buen trabajo, yo creo que la inclusiĂłn de personas permite una mejor percepciĂłn de la escala en la imagen.
Very good work, I thought the inclusion of people to improve the perception of scale in the image was particularly good.
Ben
March 18, 2024, 9:45pm
9
Veras - Release 1.6.4.2
This update only applies to the web app, and is already deployed.
Updates
Veras SDK now allows for integrations with .Net Desktop apps! Check out the SDK documentation here: EvolveLAB.Veras.SDK/DotNetSample at main · EvolveLAB/EvolveLAB.Veras.SDK · GitHub
Ben
April 15, 2024, 7:01pm
11
Veras - Release 1.6.4.5
Stability
Fixed save-as filename bug due to period in prompt for SketchUp, Forma and Standalone web app
Greg
April 18, 2024, 9:08pm
12
Veras - Release 1.6.4.6
Stability
Button which downloads latest Veras installer was broken for users of the Vectorworks plug-in–now fixed.
