The Veras - Release 1.6 introduces the V6 Render engine, which works really well with sketches. Check out the examples below using different prompts to explore materiality with a hand sketch design (credit to Dan Kalkman for allowing us to use his sketches).
NOTE: you can see the settings used to produce each render in the property pane.
