How To Get Started With Morphis
Revit_eWo3lpIPn1
About Guide
In this guide we will be explaining how to get started with Morphis, from installation to creating a layout.
How to install Morphis
  • Download and install Morphis using this link: installer
  • If succesfully installed, the EvolveLAB tab and the Morphis buttons should appear in Revit.
How to start your layout
  • Select a room, area or a filled region by clicking the select button:
    Selecting a starting layout
How to generate different layouts
  • Click “Generate”
    Generate
How to change the orientation of a region
  • Changing the region orientation allows you change the starting point of where Morphis starts adding modules
    Change region orientation
How to create paths
  • Creating a path allows you to divide areas, add circulation paths and much more. We currently have the following options to create a path:
    Revit_ig8qE4Y5BS
How to edit paths
The edit button allows you to change the path type, justification as well as delete paths you have previously created
See examples below:
Editing a user path
Revit_exigKTtc1x
Editing a perimeter path
Revit_Bo2qt6ty5b
How to edit modules
Click the edit button next to the module name
To try Morphis, you can visit our Morphis page
