Download the new version here: Morphis Installer
Layouts
You can now create Layouts, which are sets of modules, paths, and settings that can be used to generate a specific type of design. You can save, export, and import *Layouts, allowing you to use and share them between different Revit projects and users.
- Now, Morphis will open to the new Layouts View.
- Morphis comes with 7 premade layouts to get you started, covering a variety of examples such as “Workplace”, “Auditorium”, and “Parking” layouts.
- You can switch between layouts simply by clicking on a one. Your design will auto-regenerate based on the newly selected layout.
- You can create a new layout by clicking on the ‘+’ button.
- The settings for each layout allows you to edit the name and description, duplicate, or delete any layout.
- Click on the edit button to change the models, paths, and other settings of any layout.
- Use the Export button to save your layout(s) as a .morphis file, and import button to load saved layouts into you current morphis session.
Update Login System with Single Sign On (SSO)
Morphis now uses the standardized and improved login system that is used with most other EvolveLAB apps.
Some of the benefits of this new login system include:
- Ability for SSO (Note: You must first contact us to configure an SSO login for your organization).
- Reduced account creation errors by using email and password confirmations.
- Increased security, including email verification.
