Download the new version here: Morphis Installer
Area Selection
- Similar to how you can select room and filled regions, you can now select Areas as well.
Baking/Placing Rooms
- Similar to how you can bake/place walls, you can now place rooms and set any parameter you want for the newly created room
Import Modules as Rooms
- You can now import modules as rooms by following these steps:
Click Import Modules
Import Excel sheet (1) > Select a sheet (2) > Change starting cell (3) > Click Continue (4)
- Note: Excel sheet must be closed when importing it to Morphis (only when using button #1)
Map Excel sheet columns with room/Morphis parameters
[Optional] Using the first column “Morphis: Is Selected”, select which rows you will like to use for module creation
- Tip: This column is helpful as it allows you to uncheck your “titles” in your Excel sheet
Morphis will create new modules based on the parameters that you mapped
- Module wall type populates automatically
- Baking/placing walls feature has been improved. It is now faster and more reliable
Bugs
- Import modules by Excel crashing when a cell had a formula
Known Bugs
- Modules/layouts don’t show up after changing documents
- Morphis regenerates every time a room is deleted and the layout is active
- Region orientation not saved after creating new path
Guides/Workflows
- Getting to know Morphis components
- [How to get started with Morphis](How To Get Started With Morphis
