Helix - Release 2.14.0 - SketchUp 2024 Support
Download new version here: Helix Installer
  • SketchUp 2024 Support
Stability
Helix - Release 2.14.1
Updates
New SSO Login is now available:
2024-06-17 - 17-59-54 - SketchUp
Helix - Release 2.14.2
Updates
  • Fixed bug where doors or windows from SketchUp sometimes hosted to an incorrect wall, or no wall at all, in Revit
  • Fixed bug where SketchUp Helix window was difficult to unminimize.
3 posts were split to a new topic: Helix Login & Access Support
Hi Evolve lab
Wanted to test Helix out in SketchUp 2024.
Looks like in the 2.14.2 version, that it is stuck on the “Almost there” in SketchUp 2024
but in SketchUp 2023 it works.
If you’re using SketchUp 2024, you have to use SketchUp version 24.0.593 or higher.
See steps below to install the SketchUp update:
Install the latest SketchUp 2024
Thanks, it works now.
Helix - Release 2.14.3
Updates
  • Helix now supports Floating Licenses.
    • You can purchase a floating license for Helix here.
    • You can learn more about our floating licenses here.
Helix - Release 2.14.4
Bug Fixes
  • Fixed a bug with duplicate material mapping names that caused the SketchUp to Revit import to fail
  • Fixed a bug with the installer that sometimes caused Windows Defender to flag a one of the installed files as potentially unsafe
The new version 2.14.4 is also not working. The selected item doesnt show up in the Helix Window. The one time it did work there was an error showing up on Revit when trying to move over. The error said: "The family for this DXF Element either failed to be created or failed to correctly load. " . Please advise what to do.
@Tecture - I think this issue is now being tracked here: SketchUp to Revit
Let me know if that’s not the case.
Helix - Release 2.14.5
Bug Fixes
  • Fixed a bug where DWG to Revit workflows failed when the DWG was linked or imported into a single Revit view, instead of the entire model
Helix - Release 2.14.6
Updates
The login system has now migrated from the legacy EvolveLAB login to the new Chaos login!
2025-05-17 - 17-23-57 - SketchUp
