Veras - Release 4.2 - NB2 & FLF
Access
:banana: Nano Banana 2
Nano Banana 2 (Gemini Flash Image 3.1 Preview ) is now available. You can get more quota and faster render times with similar quality to Nano Banana Pro.
:film_frames: First & Last Frame Videos (FLF)
Take control of your AI video renders with First & Last Frame mode. Define both the starting and ending frame of your video — the AI generates everything in between, giving you precise, bookend-driven animations. This is a major step forward for design storytelling and presentation workflows.
Use this to guide transitions between two design states, walk through a space from entry to exit, or define a dramatic camera sweep — all with the AI filling in the motion and atmosphere.
:pill: Custom Style Chips
Quickly apply and explore visual styles with the new Custom Style Chips — prompt-assist tags that let you dial in the look and feel of your render with a single click. Create your own prompt snippets and customize the UI for quick access to steering the output toward a specific aesthetic.
2026-03-05 - 03-33-27 - chrome
More Improvements
  • Fixed resolution badges (2K, 4K) not appearing on V6S and Nano Banana renders
  • Fixed black border appearing on render thumbnails
  • Changed default local auto-save for images to be disabled — renders are saved to the cloud and accessible via the gallery
  • Fixed tooltip walkthrough positioning and display bugs
  • Fixed duplicate insufficient quota and error modals from appearing simultaneously
  • Fixed file size bug for oversized video manual uploads
  • Fixed upsell dialog display bugs
  • Improved quota refresh loading skeleton layout and spacing in the account info modal
  • Removed material and geometry override notification for Render Engine 7 (cleaner UI)
  • Improved Enscape login stability
  • Enable right click: for spellcheck fixes, copy/paste prompts, etc…
Veras - Release 4.2.1.0
Walkthrough UI Upgrades
Refreshed walkthrough interface for a smoother experience
2026-03-16 - 04-01-35 - ImageGlass
Auto-Scroll During Drag
Thumbnails now auto-scroll while dragging for easier reordering
2026-03-16 - 10-28-31 - chrome
Updated Tutorial GIF
Refreshed onboarding imagery
renderSelectionPenToolHelp
New Features
  • 3D to Revit — Experimental Feature: apply textures from the 3D Viewer to Revit materials
  • NB2 Default Engine — NB2 is now the default rendering engine
  • Slider Smoothness — Optimized slider controls for more responsive adjustments
Bug Fixes
  • Video Mode Aspect Ratio — Fixed video canvas using incorrect 1280x768 resolution instead of the proper 1280x720 (16:9)
  • Workspace Gallery Drag & Drop Sorting — Fixed drag-and-drop reordering favorites mode
  • Drag Heartbeat — Improved reliability of drag interactions
  • Parse Error Fix — Resolved a parse error when using the Enhance feature with NB2
