Access
Enscape: Select by Material and by Object
You can now render a selection by material or object for Veras in Enscape!
Optimized 3d Viewer Performance
High poly objects that should be hidden hide, and bigger objects stay visible. The FPS is consistently better.
Sun Position Controls in 3d Mode
+ More
Stability
- stability when starting 4 renders at the same time
- licensing and login stability
- fixed error when trying to save renderings who’s prompt contained ‘fancy’ quotation marks, or other similar characters
- fixed error with material selection in 3d mode
