We’re using pre-Revit 2024 Advanced Revit Sample Model for this getting started tytorial.
1. Install Veras
- Download the installer for windows here: EvolveLAB_Veras_Setup.msi
- Run the downloaded msi installer, which will add the Veras plugin to Revit under the EvolveLAB ribbon tab
2. Revit View Setup
Go to a 3d perspective view that is uncropped
Set the view to Realistic mode
Set the view to be perspective
Set the view to be uncropped
Disable the topo lines, as they will be read as design features. Type
VGthen scroll down toTopographyand unselect thePrimary ContoursandSecondary Contours
Setup the view by panning and orbiting
3. Start Veras
- Start the Veras app under the EvolveLAB Ribbon tab
4. Render the View
- Select a preset
- Click the render button
