Ben
Download new version here: Windows | Mac
Mac Update Instructions: Updating Veras on Mac
Mac First Install Instructions: Installing Veras on Mac
- better geometry detail retention with the new Geometry Override slider
- updated the settings nomenclature and tooltips for more clarity
- render setting combinations are more balanced to work in harmony, reducing poor output
- unified UI experience where the same ui used across all supported apps
Stability
- improved connectivity for Revit and Rhino
- improved error reporting UI
- SketchUp image not appearing bug fixed
- security updates
Better Geometry Details Retention
rifkin
2
FYI this is prompting to “update” to 0.9.4.5 on launch.
Ben
3
Veras - Release 1.0.1.0
- renamed the “Geometry Retention” slider to be “Geometry Override”
- inverted the values for the geometry override
- NOTE: this update has braking changes from v1.0.0.0, and requires an update
- you will receive this error if you do not update:
- fixed the update notification
- thank you @rifkin for pointing this out!
Ben
4
Veras - Release 1.0.1.3
Improvements & Stability
- altered the update notification url
- fixed Action not defined. Invalid data coming from UI… bug in Rhino
