When I log in to evolveLab Veras 1.8.0.1 with gmail, it doesn’t go forward and stops at the login point. Please fix it. My SketchUp version is 2021.
@kpk - welcome to the forum!
Sorry to hear that you’re having this issue. I have some questions:
- Do you have other versions of SketchUp where it works?
 - Did this issue just start happening, or did it never work for you?
 - Can you login using the web version veras.evolvelab.io?
To add to @Ben’s response, can you check the exact version of SketchUp you’re using? If it’s v2021.0.339, it may be related to the known bug discussed in this forum post. The current fix is to update to the latest SketchUp 2021 version, which resolves the issue.
@kpk We have just released Veras version 1.9.5, which, along with Archicad support, has a login/licensing update that may resolve this issue:
Please feel free to give it a try and let us know if it helps resolve this issue!
