New OBJ based import method with texture mapping (SketchUp to Revit)!
Available for SketchUp 2022 and above
Available for Revit 2023 and above
Revit 2024 Support!
SketchUp 2023 Support!
Import / Export Layer Mapping (AutoCAD to Revit)
Bug Fixes
Polyline processing bug patch (AutoCAD to Revit)
Known Issues
When using OBJ mapping, elements that are nested and mapped have a translation issue, when the origin of that nested component does not use the default location
Material Texture Mapping Import From SketchUp to Revit
Yes I am testing SketchUp to Revit. I am using a new model with the same method I tested before. I place all material on SketchUp model faces (this time color shade materal only). Before Helix creat new revit material for each SketchUp material, but this time all model materials have been set to “render material 255-255-255”
Thank you very much Ben for the super quick reply. I checked both links above, and they all turned to “file not found”. Will google drive or another bother you?
A thanks million again.
It works but new problem pop up. I upload an attachment to demonstrate what is wrong.
However, the original problem was not the mapping issue. I found no material transfer from SketchUp to Revit when using the default “Architecture Template” of Revit 2022. Only when I cleaned up the Revit file three times using the purge function, the material transfer would back online.
The interesting thing is, both 2.8.1 and 2.10 works fine after three times purges, but 2.10.2 patch missed some texture (see attachment).
(2.8.1&2.10)
Back to the material mapping function, I would highly recommend adding a button to renew Revit material assets on the material mapping page on the SketchUp side. Now it seems SketchUp will only get the Revit material assets to renew when hit “Sync Family Types” on the Revit side which might confuse SketchUp users who have very little idea of Revit.
The attachment link is below:
@chinadulante - found the root issue. It had to do with certain material asset names using special characters. The patch is now uploaded and DXF materials should work with both templates that you’ve tested.
