Sheet Packing Updates
Overflow Settings
- This new setting will allow you to choose what happens when the newly created views don’t fit on the sheets. This is an important setting as users will no longer need to create the right amount of sheets beforehand, and Glyph will auto create sheets for you.
- Options:
- Create a New Sheet: Glyph will create new sheets following the sheet selected schema, therefore newly created views will follow the same naming scheme
- Leave Views on the Sheet: Glyph will place the views at the bottom of the titleblock
Pre-made Bundles
For easy access, below you find the links to the following bundles so you can import them into your project:- Create room elevations views bundle: It will create the elevation views, sheets and place the views on sheets
- Create room plan views bundle: It will create the plan views, sheets and place the views on sheets
- Curtain wall bundle: It will create the curtain wall elevation views, dimension all the curtain walls, create sheets and place the views on sheets
