- Task as buttons
Add task to the EvolveLAB’s panel in Revit for easy accessibility. You can now run task without having opening the UI.
How to add task to EvolveLAB’s Revit panel?
Things to consider:
- Task buttons are saved to the project
- Settings can only be changed by opening the main UI (“Glyph”)
- Currently the feature is only available for tasks but we will introduce bundles buttons soon
Examples:
- Create room callouts
- Dimension walls in your active view
- Improved stability when using the Create Views by Room task on a room imported from a linked model and with the “Room Bounding” setting checked.
- Improved plumbing fixtures and specialty equipment dimensions when family instance host is not a wall
Bugs
- Fixed import task/bundle failing when parameter setter is not present in the new model
- Fixed room schedules not getting placed on sheets
