Rendering Interiors In Revit
Revit’s RAC Basic Sample Model | Cabin
_ cabin living room
NOTE: this workflow is pre V1 - click here for new v1 post
1 | Revit View Setup
  • Open the rac_basic_sample_project that comes with your Revit installation
  • Go to a 3d perspective view that is uncropped
  • Set the view to Realistic mode
  • Go to the Graphic Display Options… and update the settings to match the screenshot
2 | Render the View
  • Find an interesting position for the Revit view
  • Start the Veras app under the EvolveLAB Ribbon tab
  • Right click on the gray canvas, and select Show Revit Preview. This will show you the framing of the view before it will be rendered.
  • Click the Render button at the bottom of the property pane if you’re happy with the rough composition
  • If you get a network error, please see this troubleshoot post
2022-12-29 - 02-28-23
Tip: it helps to make the aspect ration of your view similar to the render resolutions selected. Ex: if square, the Revit window can be adjusted into a square ratio
3 | Living Room
All the images below share the common settings below. The only change is minor prompt adjustments in bold.
Creativity Strength: 100
Style Strength: 50
Width: 1536
All Optional Toggles are off
Prompt: living room, white walls, white ceiling, gray wood floor, forest outside seen through the larger glass windows
Prompt: living room, white walls, white ceiling, gray wood floor, forest in autumn outside seen through the larger glass windows
4 | Dining Room
Style Strength: 50
Width: 1536
NOTE: these renderings can be further defined with additional key words, ex: white chairs, wooden chairs, etc…
Prompt: modern kitchen, white walls, white ceiling, gray wood floor, forest outside seen through the larger glass windows
Prompt: modern kitchen, white walls, white ceiling, white concrete floor, forest outside seen through the larger glass windows
Tip: if you have images that are pixelated or blurry, the Style Strength might be too high. Try lowering it to 30 or below. This happens with higher Creativity Strength values
To try Veras, you can visit our Veras page
This is amazing. Great work integrating the power of AI with Revit. definitely excited to give this a try.
Thanks! I’m looking forwards to see what others can do with it!!
Rendering Interior for the RAC Advanced Model Sample
Open the rac_advanced_sample_project and follow step #1 in this post above.
1 | Armchairs
All the renderings below have the same settings except for the prompt. See prompt below each render.
Style Strength: 50
Width: 768
Is Interior: ON
All other settings OFF
Prompt: brown leather sofa, wood flooring, white walls
Prompt: white leather sofa, polished concrete flooring, white walls, city seen through large windows
Prompt: white leather sofa, wood flooring, white walls, forest seen through large windows
2 | Grand Stair
All the renderings below have the same settings including the prompt.
Style Strength: 50
Width: 1344
Is Interior: ON
Prompt: grand stair, polished concrete flooring, white walls, forest seen through large windows
3 | Sofa
Style Strength: 30
Width: 768
Is Interior: ON
Prompt: bokeh, product photo, blue couch
Prompt: bokeh, product photo, red couch
Prompt: bokeh, product photo, white couch
Prompt: bokeh, product photo, white couch, nature exterior
Prompt: bokeh, product photo, white couch in full focus, nature seen through the windows
Prompt: bokeh, product photo, white couch in sharp focus, nature seen through the windows, white polished concrete floor, white walls, white ceiling
