good morning, I’m trying veras for my company, I can’t get the geometry to stay the same as the project, Veras adds or removes objects, I would also like to use the materials I inserted in revit,
is it possible to do this?
what settings should I use? does anyone on the forum have any idea what type of pront I should use?
thanks to everyone
If you have a model that you want to preserve you want to make sure that Geometry Override is as low as possible. I would recommend a value of 0 with a max of 10.
If you have materials you would like to keep, then the Material Override would be lower. I have a hard time recommending a setting below 50 because the quality really drops unless you have very good materials to start with. The lower that is generally the lower the quality of the resulting rendering. As you are really limiting the options that Veras has to work with.
Regarding prompting, if you post the view from Revit and some general ideas of what you are looking for in the Veras output we could work one out. I’ll try to explain my thought process as I’m adding detail to the prompt. In general, I like to keep it simple and see what I get, then see what’s missing in the image and start to add language describing that. It’s not always the fix because some words are just very influential on the entire image. Water for example, can start popping up in places you don’t want it. So, I tend to use water on with Render Selection.
