We are using Sketchup 2024 in the office - so I would like to hear when you plan to have support for Sketchup 2024? ![]()
Jorgensen
Jorgensen
We have an early access release build in the works, which will provide support for SketchUp 2024.
However, please note that our current build is no longer compatible with SketchUp 2024 due to a recent update. We’re actively working on a new patch that will resolve this issue and bring back compatibility. You can stay updated on our progress by checking out the early access thread: Veras - Canary Release 1.6.4.4 - SketchUp 2024
Additionally, we’re also tackling some underlying issues with sign-in connectivity and render times in SketchUp 2024. As soon as these are resolved, we’ll be including the updated build in our main releases.
Hi Ben
Thanks for the reply.
Does this version overwrite the version I have installed for Sketchup 2023? if so - does it work ok in 2023?
Jorgensen
It doesn’t. Each extension gets installed independently for each SketchUp version.
Ok - cool ![]()
Thanks
Jorgensen
We now officially support SketchUp 2024 for Veras. The issue we were having was fixed by the SketchUp team, so you need to update to the latest SketchUp 2024 version. (Must use version 24.0.593 or higher for Veras to work properly.)
Here are the instructions on how to update SketchUp: Veras - Release 1.9 - Presets! - #2 by Ben
