I’ve been attempting to export a furniture family (following the 3d DWG to a Clean Revit Family workflow by Ben, Sep 2023). When I click on the Export to Revit (from Sketchup), nothing happens…I get a spinning wheel that never goes away, but nothing else.
I was using a trial version previously (wasn’t working). The Chair.skp file worked. I am still having issues with importing my file. The file is huge, so that may be an issue…? See link below.
Can you help me figure out why I am not able to convert 3d cad files? I downloaded your chair example file and it worked fine. I am not able to get my files to work.
I just downloaded your model, taking a shot at getting it converted. My target is Revit 2022 as its the oldest I have currently installed. Will edit this reply when I get something.
You are right on the file size! For a single section of a sofa it is a very large SKP file.
@Shana
What Ben suspected is absolutely the case. The model is just way too precise. Here in this screenshot, I have enabled the faces and edges to show and pulled up the total count.
You would want to reduce this count to something at least under 50,000 to have decent performance.
Edit:
Dug into solving the issue. There is a tool for reducing poly called Universal Importer free and open source for what it’s worth.
I was still having issues importing this model with a target of 40,000. Even at that 10x reduction in poly it was still very dense at the edges and probably why it was still hanging up. After targeting 20,000 it imported as expected.
This seems like an almost exact copy of an older message earlier in this thread. If not, can you please share a screen shot of what you see when you run into this issue? Then we can further assist you. Thanks
