Glyph - Release 1.3.0.0
Features :tada:
Progress Bar
Progress bar
Live Changes
Live changes
Bugs :bug:
  • Fixed scope box elevations/sections not getting placed on sheets
  • Fixed tagging linked elements in elevations/sections
This is cool! So it like refreshes both the progress bar in the UI, AND the current Revit view on the screen?
Does the progress bar work for all task types?!
Correct! It will refresh the progress bar in the UI and Revit as well. The progress bar is included on all tasks/bundles.
Ever since I updated to 1.3, I keep getting this error when I try creating views by room. I tried rolling back to earlier versions but this error now keeps popping up. What could be going on?
Hi @surajsankar ,
Thanks for posting this Bug. Can you send me a photo of the room you are trying to place and the task settings?
Thank you!
Hi @Miguel,
This has happened with multiple rooms, but here is the room I had posted.
For context, I am running the plug-in in a model where all model elements are linked from other files, but the rooms have been copied over to this host model (so that Glyph plug-in could pick it up).
Thanks for posting more information about this bug. I was able to replicate it my end and we will be releasing a new version soon.
Note: It looks like it is a logging error, as it doesn’t affect the outcome. The elevation cropboxes are still set to the boundaries of the room
GLYPH 1.3.0.1
To install the new version, please use the link above.
Bugs :bug:
  • Fixed logging report issue when creating elevations based on rooms
@Miguel,
Thanks for picking this up so quickly. Agreed that it’s a logging error, the elevations are still created just not placed in the sheets. The error blocks the “Use previous output” from going through.
Anytime! Stability/bugs are our #1 priority. I just released 1.3.0.1 so please let me know if it still doesn’t place the views on the sheets once you try the latest release.
Thanks!
GLYPH 1.3.1.0
Features :tada:
  • Polish language support
GLYPH 1.3.1.2
Bugs :bug:
  • Linked models not showing up for tagging
  • Far clip offset not visible in list of parameters
GLYPH 1.3.3.6
Bugs :bug:
  • Fixed duct tagging not working
  • Curtain wall dimension offset setting now works with meters
  • Fixed Curtain wall parameter “type” not setting correctly
  • Fixed place views on sheets task not working on none English Revit versions
GLYPH 1.3.3.8
Bugs :bug:
  • Fixed create views by category task not working properly when creating elevations based on casework
  • Fixed null value while updating the progress bar. - (Released 1.3.3.7)
  • Fixed null value while using the sheet packing mapper - (Released 1.3.3.7)
GLYPH 1.3.3.9
Bugs :bug:
GLYPH 1.3.4.0
Bugs :bug:
  • Fixed error when max offset from element setting is less than “1 (ft/meter)” and annotation collision is turned on. (Tag views/sheets by category)
GLYPH 1.3.5.0
Features :tada:
  • Create views by category task - New setting: View orientation + elevation marker offset
Bugs :bug:
  • Fixed “Start Index” error when the naming scheme is empty
  • Fixed viewport type without a title affecting sheet packing
  • Fixed foundation dimensions
  • Fixed linked doors/windows not tagging
GLYPH 1.3.5.1
Bugs :bug:
  • Fixed 3d views not getting placed on sheets - Create views by category task
