Where are tasks saved?
- All settings, including name, description, filters, view templates, dimension options, and more, are saved within the Task or Bundle. Tasks and bundles are saved inside the Revit project when the Glyph UI is closed.
- We recommend creating tasks and bundles within your Revit starter project or Revit template for best workflow efficiency.
How can I export these tasks and bundles?
- You can export tasks and bundles using the import/export buttons in the Glyph window. For more details on exporting and importing, visit this link: How to create, duplicate, delete, export, or import tasks/bundles.
Why can’t I run a bundle I created?
- You may be unable to run a bundle if certain elements in the task have not been selected. To resolve this, change the “Element Selection Option” to either “Output from previous task” or “Select new elements.”
What kind of data does Glyph Copilot use or collect?
- Glyph Copilot does not collect any Revit model data. It uses only your prompt, message, or request to locate a matching Glyph task. It then uses Glyph’s capabilities and features to run the task.
My task failed. How can I find out what happened?
- Using the status report, you can view what Glyph created and any warnings that occurred while running the task or bundle.
