Convert Stadium from SketchUp 3D Warehouse to Revit
2022-09-19 - 13-50-25
1 | Download the SketchUp model from the 3D Warehouse
  • Download the model from SketchUp Warehouse, using link below
2 | Setup SketchUp Model Tags
  • Create Tags for Helix to map as Revit Family Categories
3 | Tag SketchUp Geometry
  • Place the SketchUp geometry on the correct tag
  • For surface based elements, place the SketchUp face onto the correct tag.
    Ex: walls, curtain walls, floors, roofs and ceilings
4 | Map Component in Helix
  • Open the the Helix UI by clicking the Helix Icon in SketchUp
  • Select the chair component and set it as Mesh (DXF)
    • Alternate is to place this component on a tag
  • Select the other tags and map them to Revit Categories.
5 | Send Mapped Geometry to Revit
  • Press Send to Revit button on the SketchUp Helix UI
    You should get a Sync Completed notification
6 | Load SketchUp Geometry in Revit
  • Back in Revit, press the Load Model button on the EvolveLAB ribbon tab → Helix Panel
NOTE: this example only loads a quarter of the model and a specific portion of seating, hence the ~3600 seat count instead of ~65,000
2022-09-19 - 13-52-35
7 | Swap out the Seat Families (Optional)
  • Select all the seat families
  • Change the family type to the new type
  • Rotate the family if the Helix generated does not have the same orientation by pressing space bar while the seat families are selected
Ideas & Feedback
Here are some ideas that we think could improve this workflow. Let us know if you can think of other ideas.
  • mapping the seat family directly in Helix, so that users do not need to swap out the family in Revit
  • setting for angle adjustment when mapping, as different families have various orientations
  • ability to send the family from Revit as a mappable component in SketchUp
To try Helix, you can visit our Helix page
