Convert SketchUp Point Cloud Mesh to Revit 3d Object for Documentation
2022-02-12 - 00-11-25
Sample Files
Auditorium_Ceiling_Scan_Partial_SU2023_01_base.skp
Auditorium_Ceiling_Scan_Partial_SU2023_02_tagged.skp
Auditorium_Ceiling_Scan_Partial_R2024_01_final.rvt
1 | Convert the Point Cloud to a Mesh
Alternates: can use other point cloud to meshing tools, then bring the generated mesh into SketchUp
– MeshLab: open source and free
– Cloud Compare: free
2022-02-12 - 00-14-45
2022-02-12 - 00-17-19
2 | Place Mesh Geometry on Specific Tag (Layer)
  • Select the point cloud geometry, and place it on the appropriate tag
TIP: It might be best to create a new tag to ensure that the only geometry present on the tag is the point cloud mesh
TIP: Can set the color by tag option to visually see what geometry is set to a tag
2022-02-12 - 00-28-20
2022-02-12 - 00-29-43
3 | Map Tag in Helix
  • Open the the Helix UI by clicking the Helix Icon in SketchUp
  • Select the component
  • In the SELECTED ELEMENTS section change the selected Layer “LIDAR3” (newly created tag) to DXF in the dropdown
2022-02-12 - 00-33-13
4 | Sync with Revit
  • Click the Sync SketchUp button in the Helix UI
  • With Revit open, click the Load Model button in the EvolveLAB Revit Ribbon Tab
2022-02-12 - 00-35-23
5 | Continue Process for the Entire Model
  • Continue and add the other tag to sync with Revit so that all the desired geometry is translated.
  • Can also set all the desired geometry to the same tag used in the second step
2022-02-12 - 00-39-17
6 | Create Views in Revit
  • Create section, plan, or rcp views in Revit
2022-02-03 - 22-18-08
7 | Document the Revit Views
  • Use the imported point cloud mesh as a background along with other BIM geometry
  • Can also add dimensions to the imported mesh geometry:
    – dimensions to self
    – dimensions to other BIM content
2022-02-03 - 22-22-43
2022-02-12 - 02-35-10
Ideas & Feedback
Let us know how we can improve this workflow.
Are there other ideas that could be useful to this workflow?
