Why does it not adhere to the prompt? Also facing a lot of issues with controlling the lighting. Kindly guide.
Can you share more about the render settings used? It would be helpful to know the Geometry Override settings, Material Override, and Prompt Strength.
I’m assuming the reply below applies to this post as well:
Having the material override so low, limits the amount that the prompt can be adhered to. By increasing the material override, it allows the prompt to take more autonomy and be less constrained.
