Alpha Testers Wanted: Morphis v2
We’re looking for mechanical engineers, lighting designers, architects, or BIM enthusiasts who are interested in testing the alpha release of Morphis v2 — and we’d love your help.
What is Morphis?
Morphis is a generative design add-in for Autodesk Revit. It helps you generate and edit lighting and air duct designs, and then when ready “bakes” them directly into your model using native Revit families. The demo above gives you a quick look at what it can do today.
What’s new in v2?
v2 is a ground-up rewrite. If you tried Morphis before, expect a significantly different experience. v2 will start with an MEP focus (as opposed to the old spatial layout designs of Morphis v1), and use a different more flexible approach to generating the designs.
What we’re asking
- Try it out on your real projects and models
- Tell us what works, what doesn’t, and what’s missing
- Share your ideas — this is the stage where they can actually change the product’s direction
Alpha testers get early access and a directly line of communication with the Morphis dev team. When publicly released, we plan to offer continued discounted access to Morphis, and potentially other Chaos products as well.
Interested?
Fill out this form, and we’ll reach out to you shortly!
https://docs.google.com/forms/d/e/1FAIpQLSfmjFWd5wkP2WCtaT-F5f5UwabZvgy67CchAmyLBEeEUOsgJw/viewform?usp=publish-editor
