Hi, I´m trying to install Veras on Revit 2024.2 but it says that is not possible to install. Does 2024.2 update on Revit is not compatible with Veras?
@Oli21 - welcome to the forum!
Veras should work in Revit 2024.2. Here are some questions:
- Did you close out of Revit first?
- Does Veras work on any other version installed?
- Are you using Revit LT?
- Do other plugins work?
Thank you for your reply.
I managed to install it finally.
