Veras is not displayed in Revit
Hi!
I downloaded the Veras and wanted to try the free trial period for Revit 2023.
After installing the Veras there is no icon of it in Revit.
Thank you in advance.
@Andrii - welcome to the forum!
When you install Veras, you have to make sure that Revit is closed. If you didn’t close it and didn’t get any errors, you have to restart Revit.
There’s also an alternate install process: You can try this link instead: EvolveLAB_Veras_Setup.zip
You will have to unzip the file and run the msi file.
Thank. The problem solved.
