Veras installed but addin not showing in SketchUp 2023
Veras installed accessible in Revit and Rhino but not accessible/showing in SketchUp 2023.Not in View>Toolbars. Please advise how to enable in SketchUp 2023 on PC
Thanks for reaching out with your question!
If the extension is not enabled, then it will not show up in Toolbars… (I am not sure what would cause the extension to not be automatically enabled.)
You will have to go to Extensions>Extension Manager. The Veras addin should be listed there as “EvolveLAB - Veras”, and you will need to click on the Enabled/Disabled button.
Following this step (and a possible restart of SketchUp2023), Veras should be included in the Toolbars list.
Please let me know if this does the trick, or if you run into another issue – such as Veras not appearing in the Extension Manager.
You could also try to manually install the SketchUp extension using the “Mac” instructions. The instructions are almost identical for Windows manual install: Veras SketchUp for Mac - Release 0.9.4.5
Hello , looks like the person had the same issue back in 2023. My extension is enabled and there is no tool bar that usually pops up immediately after any plugin installation. It does not appear in the toolbars.
Sometimes the toolbar is detached, and somewhere else on the screen, which can make it hard to find. Do you not see the plugin listed under the “Extensions” menu either?
