Hello,
I tried to download Veras from official site (https://evolvelabbim.bitbucket.io/veras/release/EvolveLAB_Veras_Setup.msi) but not works for me. Please check the screenshot below,
Thanks for your support.
Hello,
@berk.gulher - welcome to the forum
You can try downloading the zip file, and then unzip the installer. See steps below:
Thank you but this solution is not working too.
Regards
It seems like you have a firewall rule or some kind of restriction on accessing our bitbucket link. Can you try to whitelist the https://evolvelabbim.bitbucket.io address?
this is for Mac or windows?
@hannelodie - you just need to rename the file and change the extension from .txt to .rbz.
This happens with some browsers downloading files.
The .rbz should work on your Mac.
it works now thank you !
