I decided to give it a go at Veras, to explore early concept images for a masterplan I’m currently working on, I downloaded and installed the sketchup version, unfortunatelly is giving me an error as per the attached snip.
I tried updating the version from 0.9.4.5 to 0.9.4.8, still having the same issue, I have Sketchup 2021 pro, still looking for a solution to the issue.
Thank you very much for having a look into the issue, the problem is persistent on the company provided laptop, I managed to install the 0.9.4.5 version on my personal computer, and is working fine so far! at some point I got error 400, I saved the Sketchup file, closed everything, open it back again, and the error was gone!
The latest release has a better error messaging system that will help us address the 400 error you received. If you run across this issue again, please take a screenshot so we can further investigate.
