I am not able to load the model from Sketchup 2021 into Revit 2022. I started a new sketchup, created a box, colored the box red, selected the box after clicking Sync Family types in Revit. Selection drops down to Map Board, Select “Wall” Select a revit 6" generic wall type and click Send to revit. The Grenn box states it was transmitted. Click in Revit the Load Model and nothing happens.
I can send model information from Revit into Sketchup without a problem. NOTE: Circles and Arc faces don’t convert.
Ben,
It’s just a new Sketchup 2021 file? Here is the Revit screenshot of the Error. I did remove and re-install the program with the same results as before.
This could be an issue with Windows 11 (noticed from the window screenshot). We want to test whether the Helix Hub is running in the background. Can you follow these steps, and let us know what you see:
Thanks Ben,
If you are needing BETA still on GLYPH let me know and I would be happy to help out. I have done Beta for Buildedge in Sketchup several years ago, and currently do beta for Presonus Audio interfaces. 11 years in Sketchup and 30 years in Construction Documents. I have a long list of programs I have used for Architectural 3d Modeling, Animations and Rendering.
