Hello, I am trying veras for the first time with sketchup 2024. Are they compatible? I can’t get the model to show up inside the veras window…thanks for your help!
We do now support SU 2024, though the SU version must be 24.0.593 or higher. Is there an error being displayed when the model is being unsuccessfully “refreshed”?
Also… noticing you are a MacOS user. Will double-check that we fully support SU 2024 on Mac.
SketchUp 2024 for Mac is supported, but you need to use the latest update.
You can try to upload to the latest SketchUp version: For MacOS, go to the SketchUp menu and click Check Web for Update.
If that does not work, you can change the directory for where the files are stored:
