How can I create dependent views from existing views with scope boxes? I can see no way to select for example a group of floor plans for doing that. I need to split each floor plan view to several dependent views that are cropped with several scope boxes. I can only select building stories. How can I select views?
Hi @shlomi ,
You can achieve this by changing the following settings:
Note: Currently you can only select one parent view but shortly you will be able to choose multiple parent views simultaneously.
