Error: Render Failed
Render failed due to the following error:
Error: Request must have customer_email in body.
Please advice
Please advice
Hi, I am having same issue. Running on windows. Trial version.
Are you using a VPN?
Hi, I´m having same issue. Windows trial version on Sketchup 2023. no using a VPN
Thanks in advance
Hello
same for us at the office
mac Skp 2023
pc skp 2022
thanks
@Romain - Thanks for lettings us know! We’ve heard about this issue from a few users, typically with SketchUp and Mac, and we’re currently trying to find a solution. We’ll post an update once we have this issue solved! Thanks,
With the release of Veras standalone, can you test and see if this version works? Go to this url: https://veras.evolvelab.io/
Same error: windows - revit 2023 plugin - please solve the problem.
Last week I hadn`t - today I have. But I need the plugin function - not the stand alone version. Thank you!
I see. Using the plug-in, did some of the renders work? Or we’re you not sure to use the plug-in at all?
