The openings on the second floor exterior wall in the sketchup modeling are not applied in the conversion. The openings on the third floor are reflected in the conversion, but I can’t tell the difference. The light blue sides and the magenta doors on the first floor are also not formed. I have tested several times to see what step in the process is missing, but I can’t figure it out.
@jm929bae - welcome to the forum!
Would it be possible to share the skp model?
@jm929bae I’m looking into another Helix bug this week, so I can try to resolve this one too.
Like @Ben said, if you can share your skp model, and maybe also the Revit one, it would be super helpful. I’m wondering if it might be a language conversion issues that’s causing the mappings to not work correctly?
You can send either of us a direct message with the files or a link to them, or post them right in this thread if they aren’t too big.
Also, Would you be able to scare a screenshot of the ‘Status Report’ Helix window (from Revit) with us? This may shed some light on which mappings failed and why.
