Re-order Tasks within Bundle
Hello,
Is there a way to re-order the tasks within a bundle? For instance, I want to create a Demo Plan and a New Work plan, easy enough. Then create the sheets that these go on. Since they are different series and have different legends, I created two separate tasks. Then I need to place them on the sheets.
I essentially have 3 tasks for each series. When running the bundle, all the views are ending up on 1 sheet. If I could reorder the tasks it would solve the issue. Create View → Create Sheet → Place on Sheet, repeat for the next series.
Any recommendations? Thanks!
Hi @tbrozovich,
If I understand correctly, you will need two different bundles.
Bundle #1: Demo Plan Sheets
  • Create views by level or scope box
  • Create sheets by level or scope box
  • Place views on sheets
Bundle #2: Work Plan Sheets
I hope this helps.
