When creating sheets in a bundle is there a way to place views that are named by parameter onto a sheet named the same? example… walls have a parameter that names them A_001 ect. this is also for the elevation and 3d. However it randomly places them on a sheet. I would like the sheet to be named A_001 so that it corresponds to the views named the same.
Hi @chris.wilson ,
You can achieve this by creating a bundle that combines the following tasks:
- Create views by category
- Create sheets by category
- Place views on sheets
This will create one sheet per element selected
Does this help?
Thanks!
I have done the bundle, it however places the A_003 views on the A_001 sheet. I might be missing something in the set up
Good to know. Can you post a photo of the settings inside the “place views on sheet” task, if possible?
Thank you for posting a photo of the setting!
I just ran it successfully. Can you confirm you are selecting the same elements for the following tasks?:
@chris.wilson, I just sent you an email.
