When running the place views in sheets bundle I am running into an issue where its places the plan and elevation correctly, however it is no placing the 3d views even thought it has created them. I have also checked reduced the scale to see if that was an issue. Any ideas or suggestions?
This usually happens when your sheet pack layout has no zone with a 3d view type selected.
Can you post your sheet pack layout and settings?
Thank you!
Thank you for posting the settings. We were able to replicate this bug and we will release a new update today.
Note: For the view template assigned to the 3d view, we highly recommend you hide the following elements:
- Shaft openings
- Scope Boxes
I have made that adjustment , scope boxes were already off.
