Download the new version here: Morphis Installer
Import and Export Modules
- Import
- You can now import modules using an excel sheet or using the exported Morphis module file
- Export
Programmed Module Count
- Locks the amount of modules you need for that specific type
Module Count: Amount of modules per module type
Range: The amount the module count could vary and remain on target
Lock: When locked the module count will be capped at that range. When unlocked, the module count will not be capped but it will still show in the UI.
Toggle: When checked, module count feature will be turned on.
- Temporary Modules Settings
- When all the modules are locked and there is an excess space in your layout drawn, then Morphis will created temporary modules.
- These modules can be hidden using the display settings
UI/UX
- SnackBar
Bugs
- Fixed layout always re-generating
