Ben
2
Morphis - Release 0.6.1.0
- link multiple layouts mode
- only remove active layout on delete button & and remove all if in link multiple layouts mode
- refresh all active layouts on Revit model changes and display settings changes
Stability
- fixed bug with multiple layouts drawn & switching between them
- patched unsubscribe keyhooks Revit
Link Multiple Layouts Mode
Ben
3
Morphis - Release 0.6.2.0
- selected perimeter paths have a path type selection dropdown
- perimeter path change affects all layouts when in linked layouts mode
- Revit doc update changes consistently with the linked layouts mode on Revit doc changes
Stability
- fixed deleting modules bug
- fixed family rotation about center bug
- fixed bug when picking new line after drawing a user path
- fixed outdated final pass geometry (had to press regen to update)
- fixed the highlighted geometry not being updated when Revit changes
- fixed issue with user drawn paths disappearing when multiple layouts are regenerating
Path Type Dropdown for Selected Path
Ben
4
Morphis - Release 0.6.3.0
- path justifications!
- you can change the path to be right, left or center justified
- you can also set the path justification when making the path
Stability
- fixed bug when deleting paths linked to model lines
- fixed bug where selecting an new path with other instance settings would regenerate the design while in edit mode
Path Justifications
Ben
5
Morphis - Release 0.6.4.0
- bake module walls!
- can select which wall of the module to bake
- can select the wall type to bake
- wall cleanup algorithm keep walls as one element when multiple walls are collinear and of the same time
Bake Module Walls
Does Morphis work for Revit 2024?
Ben
7
Not yet. We’re going to add Revit 2024 support soon.
Morphis now supports Revit 2024! Download the new installer here: Morphis - Release 0.7.0.0 - #2
