I am having some issues with Helix converting CAD to Revit. I have tried multiple avenues with the most recent being a CAD layer for everything I am trying to convert. (ex. Interior wall, Exterior Wall, Interior door 2468, Interior Door 2668) Each category in the example are on the corresponding layers. I am initially using AutoCAD Arch. but converting the file to AutoCAD for the linework. Helix recognizes the layers but it seems to pick and choose what walls to place. I have set the Juncture and set rules for 2x4 vs 2x6 walls etc. but there are still walls that seem to not be getting picked up. As well as some of the openings. I am not sure why this is the case. There also seems to be a few of the walls coming in 1/4" off of the stud wall alignment. Below is an image of what is wanting to come through. The black walls and black openings are not in the model but are in the DWG.
Happy to help, could you share over the CAD file? You could send it here on the forums through a DM if it’s under 4MB. I would like to try and replicate the issue you are having.
